09-21-2013 11:23 PM - edited 03-16-2019 07:29 PM
Hi.could you help me, please. I have a number +XXX (XX) XXXXXX and when I dial this number, I can't call. Answer to me please: if it is possible this setting and if it is possible, where I can find it: in CUBE or CUCM??? PLEAS!!!!!!!
09-22-2013 08:00 AM
Inbound???
Outbound call??
Call flow??
09-22-2013 08:13 AM
outbound call
09-22-2013 08:25 AM
If you don't provide enough details and the exact behavior you're seeing, theres no way you'll get an answer.
09-22-2013 01:31 PM
Hi.
Please give a look to this doc.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010000.html#CUCM_RF_UAD8BE59_00
Carlo
09-22-2013 11:26 PM
I set on route pattern \+!# and at \+.0!# but is doesn't work.
09-22-2013 11:34 PM
Hi.
You can try
discard digits pre dot
prefix outgoing 00
Carlo
09-22-2013 11:53 PM
thanks for answer, but it do not work. "your call cannot be completed as dialed please consult your directory ..."
09-23-2013 01:06 AM
Hi.
What signaling protocol have you configure to reach your voice gateway? (MGCP/H323/SIP)
Check also the partition you have configured the suggested Route Pattern.
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-23-2013 04:04 AM
09-23-2013 05:37 AM
Hi.
Can please post a show run of your VG and a debug voice dialpeer inout during a call to an E.164 number?
Carlo
09-23-2013 05:43 AM
no i don't
09-23-2013 05:53 AM
In this case we can't help you.
Carlo
09-23-2013 06:04 AM
thanks for help
09-28-2013 10:54 AM
It appears you are requiring the # character at the end of the phone number, and also sending that to the telco. (I cannot see the entire route pattern or translation pattern in your post.)
Try sending the number without the #
D
