CUCM 9.1 Licenses file export
Any ideas how to get the license files installed on the CUCM 9.1?
need to export these files out.
Regards.
Mohamed Helmy
Regards, Mohamed Helmy
Hi Mohammed.Licenses in 9.1
Hi Mohamed.
Licenses in 9.1 are managed by Enterprise License Manager which could be a standalone server or integrated within CUCM.
In system --> License --> License Usage report page you'll find the ELM server address as shown on attached screenshot
If is the same address of cucm, you can browse it at https://<CUCM IP Address>/elmadmin and login with cucm application account
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello Carlo, Thanks for your
Hello Carlo,
Thanks for your answer.
How can i download these files from the ELM ?
Regards.
VIP Purple
Hi,check for this linkhttps:/
check for this link
https://supportforums.cisco.com/discussion/12009031/cisco-elm-file
regds,
aman
374
