Community Member
CUCM 9.1 UCS question
We're planning a fresh 9.1 instalation on a UCS server and would like to know what our options are in case of a hardware failure. Would it be possible to move a copy to a different server? What issues and procedures would be necessary regarding the licences?
Besta regards,
Ivana
1 ACCEPTED SOLUTION
What you can do with ESXi is here:
VMware Feature Support for Unified Communications 8.0(2) through 9.x
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#VMware_Feature_Support_for_Unified_Communications_8.0.282.29_through_9.x
Assuming you have all the VM files in a SAN and no ESXi failover mechanism, you can just register the VM in another server.
If you have co-res ELM, same applies, if standalone, and on another server, no need for anything regarding licensing, if co-res, still nothing needs to be done.
If you have the files IN the server and they fail, and the HDD fails, then DRS is your only choice.
Either way, you should have a DRS schedule in place.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Jaime +5 beat me to it
Yosh
HTH Regards, Yosh
Ivana,
The link below should answer most of your questions.
http://docwiki.cisco.com/wiki/Unified_Communications_VMWare_Requirements#VMware_Infrastructure_Feature_Support
Yosh
HTH Regards, Yosh
Purple
Hi Ivana,
The licenses are no more binded to MAC address of servers and are ELM based.
secondly, the backup are platform independent.
redgs,
aman
145
