CUCM 9.1 Unrestricted
Doing a CUCM installation in VM, UCS 220 Server, Installed with OVA 9.1 v8_v1.7. Soon after deploying the ova, i had edited the HDD size from 110GB to 250GB, and begun the installation for cucm9.1. When i finish the installation its shows error: 'unaligned partition' in CLI as well as CUCM Administration page.
What i noticed is, if i wont edit, there wont be error at all. So if i install without editing the HD Size, can i edit the HD size and make it larger after the CUCM installation? Will it make any impact on the system later?
tnx
Bobby
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Bobby,
Just thought you should see this clip as well in addition to the
excellent info from our friend Java (+5 Java-man!)
"The VMware installation information line will indicate  "ERROR-UNSUPPORTED: Partitions unaligned". If your virtual machine is in  this state, Cisco cannot provide support for performance issues."
From these bug notes;
Include partition alignment check in "VMware Installation" CLI & GUI
CSCug69836
Just curious as well as to why you are using Unrestricted? It is a bit uncommon in
most installs
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Read here:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#Resize_Virtual_Machine
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Bobby,
CSCug69836
most installs
Cheers!
Rob
- The Band
Many Thanks Rob,
Yes, unfortunately our 8.6 were Unrestricted, we are upgrading to 9.1 now.
Tnx
Bobby
580
