CUCM 9.1.x Supported Devices
Hi all, hope everyone is doing well.
I am researching into upgrading my CUCM 7.1.3 evironment to 9.1.x. I understand Cisco recommends that all IOS gateways should be running IOS release 15.x. for CUCM 9.1.x. The scenario with me is that most of my routers/voice gateways are on 12.4 and some older ones are supported on IOS 15.x. Is this really a must have requirement for CUCM 9.1.x ? I have both H323 and MGCP gateways in my environment.
On some of my older routers I have NM-HD-2V with VIC2-4FXO. Does CUCM 9.1.x support these modules ? Any issue with first generation PVDM ?
Thanks all in advance !! I appreciate any inputs / suggestions !!
Danny
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
All of them are supported just fine, you do not need to upgrade any IOSes either.
Chris
Chris
Hi Chris !! Appreciate your response !!
I have a few 3725 routers/voice gateways and these are not supported with IOS 15.x. I would have to do a router refresh if IOS 15.x is a must have for CUCM 9.1.x.
Thanks Chris !!
Danny
228
