CUCM 9 SUB Database replication
Dear
The database replication for only 1 subscriber is not working for another 2 subscribers is perfect the i did the reset and stop for Database but no effect.
according to the link below but no susccess.
https://supportforums.cisco.com/document/52421/troubleshooting-cucm-database-replication-linux-appliance-model#checking-current-replication-status
Cluster Detailed View from CUCMPUB01DC (4 Servers):
                                PING            CDR Server      REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    (ID) & STATUS   QUEUE   TABLES  LOOP?   (RTMT) & details
CUCMPUB01DC    10.X.X.X      0.027   Yes     (2)  Connected   0      match   Yes     (2) PUB Setup Completed
CUCMSUB01DC    10.X.X.X     0.499   Yes     (?)  Off-Line    N/A    0       N/A     (4) Setup Completed
thanks
1 ACCEPTED SOLUTION
Your backup is probably
Your backup is probably failing because of the dbreplication issue. If you don't have a recent backup and are nervous of something bad happening by running the "dbreplication reset all" command then I would just delete that SUB and re-install.
Yosh
HTH Regards, Yosh
Did you just install this Sub
Did you just install this Sub? Has this Sub ever worked?
Yosh
HTH Regards, Yosh
yes this SUB was working
yes this SUB was working before and due to replicating status (3) mismatch in tables i did a  reset for specific this server and also did a repair but no luck,
I have 2 question please answer.
Now i have spend plenty of time in solving this issue if i delete this sub from CUCM PUB and i will delete the subsriber VM completely and i then i will fresh install the new subsriber, will it affect disturbance in PUB database .
By mistake i  type a command on publisher utils dbreplication < publisher itself> and now all the nodes are off-line how to get them connected.
thanks
Samuel,You may need to
Samuel,
You may need to perform the following.
run the following command on all subscriber servers:
utils dbreplication stop
Then, run the following commands on the publisher server:
then
utils dbreplication reset all
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/trouble/9_0_1/CUCM_BK_T863AF5C_00_troubleshooting-guide-cucm-90/CUCM_BK_T863AF5C_00_troubleshooting-guide-for-cucm_chapter_011.html#CUCM_TP_D31B2F41_00
Yosh
HTH Regards, Yosh
VIP Purple
Hi Samuel,[+5] to Yosh . you
Hi Samuel,
[+5] to Yosh .
you can try the steps provided by Yosh. Deleting the subscriber and doing the fresh installation is not going to harm any working IP phones registered to working PUB and SUB.
Since you are doing the fresh installation of Subscriber 2, you need to delete Sub from  from PUB and add it again.
regds,
aman
i will carry out the steps
i will carry out the steps and i will reply back
thanks for the reply yosh and aman
Dears Do I need to take a
Dears
Do I need to take a backup before running the commands??, or they will absolutely not crash the system as I am afraid becz if anything goes wrong I have to reconfigure the whole CUCM.
thanks
It never hurts to have a
It never hurts to have a backup.
Yosh
HTH Regards, Yosh
that's the reason I posted
that's the reason I posted for tftp error, becz I preferred to be little late & safe.
Yosh
HTH Regards, Yosh
so you are confirming me that
so you are confirming me that instead of running the propose commands if I delete the subscriber and reinstall that will be more quicker and safer, which will not affect in existing publisher database.
Also I get the attached error between the publisher and subsribers, I have done the below but still. this all I s happening becz of database failure.
set cert regen tomcat
utils service restart Cisco Tomcat
thanks
I'm not saying it's quicker
I'm not saying it's quicker but it can be "safer". The reset all command is just going to force all the Subs to re-sync. It's almost like a broadcast to the Subs. Please see the below information and link, which is a great document!
Using Replication Commands
Meaning of each command
After verifying that we have good connectivity and all the underlying hosts files are correct and matching across the cluster it might be necessary to use CLI replication commands to fix the replication problem. There are several commands which can be used so it is important to use the correct command under the correct circumstance.   The following table lists each command and it's function.  Certain commands are not available in each version of CUCM.
commandfunction
Normally run on a subscriber. Stops currently replication running, restarts A Cisco DB Replicator, deletes marker file used to signal replication to begin. This can be run on each node of the cluster by doing “utils dbreplication stop”.
In 7.1.2 and later “utils dbreplication stop all” can be run on the Publisher node to stop replication on all nodes
utils dbreplication repair
utils dbreplication repairtable
utils dbreplication repairreplicate
Introduced in 7.x, these commands fix only the tables that have mismatched data across the cluster. This mismatched data is found by issuing a utils dbreplication status. These commands should only be used if logical connections have been established between the nodes.
utils dbreplication resetAlways run from the publisher node, used to reset replication connections and do a broadcast of all the tables. This can be executed to one node by hostname “utils dbreplication reset nodename” or on all nodes by “utils dbreplication reset all”.
utils dbreplication quickauditCheckes critical dynamic tables for consistency.  To check all tables run utils dbreplication status.
utils dbreplication clusterreset
Always run from the publisher node, used to reset replication connections and do a broadcast of all tables. Error checking is ignored. Following this command 'utils dbreplication reset all' should be run in order to get correct status information. Finally after that has returned to state 2 all subs in the cluster must be rebooted
Note:  This command is no longer functional as of CUCM 9.0(1).  Use "utils dbreplication reset all" instead.
utils dbreplication runtimestateAvailable in 7.X and later this command shows the state of replication as well as the state of replication repairs and resets. This can be used as a helpful tool to see which tables are replicating in the process.
utils dbreplication forcedatasyncsubThis command forces a subscriber to have its data restored from data on the publisher.  Use this command only after the 'utils dbreplication repair' command has been run several times and the 'utils dbreplication status' ouput still shows non-dynamic tables out of sync.
utils dbreplication dropadmindbRun on a publisher or subscriber, this command is used to drop the  syscdr database. This clears out configuration information from the  syscdr database which forces the replicator to reread the configuration  files. Later examples talk about identifying a corrupt syscdr database.
utils dbreplication dropadmindbforceSame as above, but may need to be used in cases where above command fails
utils dbreplication setprocess
Sets the "process" value within Informix.  This enables multithreading and improves replication setup time at the slight cost of processing power.  Recommended to set to 40 for large clusters (10+ nodes).
Yosh
HTH Regards, Yosh
Dear yosh,Do I need the below
Dear yosh,
Do I need the below command as well.
Utils dbreplication dropadmindb (PUB)
utils dbreplication dropadmindb (SUB)
thanks
Samuel,You don't need to run
Samuel,
You don't need to run those commands.
Yosh
HTH Regards, Yosh
Dear Yosh,I have run those
Dear Yosh,
I have run those commands but the status is below, thesub1 came in status of (3). and sub2 and sub3 in status of 4.
sub2, and sub3 are in status of 4 this can be becz of the error attached,
CUCMPUB01DC    10.X.X.X      0.042   Yes     (2)  Connected   0      match   Yes     (3) PUB Setup Completed
CUCMSUB01DC    10.X.X.X      0.319   Yes     (5)  Connected   0      match   Yes     (3) Setup Completed
cucmsub02dc    10.X.X.X     3.759   Yes     (?)  Off-Line    N/A    match   No              (4) Not Setup
cucmsub03dc    10.X.X.X     3.702   Yes     (?)  Off-Line    N/A    match   No               (4) Not Setup
On sub02 and sub03
i see the below
admin:utils dbreplication runtimestate
Replication is not setup, exiting...
thanks
VIP Purple
Hi Samuel, Have u added these
Hi Samuel,
Have u added these two subscribers in Publisher ?please let us know what is  10.20.15.15 in attached snapshot.
regds,
aman
I have rebooted the whole
thanks for the reply aman,
i have just put the fake ip's so pls don't consider.only consider the error " unable to connect node"
those were added from start and the attached error is when accessing the subscriber 2 and subscriber 3, from the serviceability page from the publisher
I have rebooted the whole cluster and Now the status is as below
CUCMPUB01DC   10.X.X.X       0.050   Yes     (2)  Connected   0      match   Yes     (2) PUB setup completed
CUCMSUB01DC    10.X.X.X       0.392   Yes     (?)  Off-Line    N/A    match   Yes     (4) N/A
cucmsub02dc   10.X.X.X      3.657   Yes     (7)  Connected   0      match   N/A     (0) Setup in progress
cucmsub03dc    10.X.X.X      3.776   Yes     (8)  Connected   0      match   N/A     (0) Setup in progress
DearsThe problem is solved,
Dears
The problem is solved, there was  port (8500)  blocked on network side for subscriber to other subscribers but it is strange that between the subscriber 8500 was not reachable and the node was seen off-line, i was thinking that the replication is done by publisher to subscriber but by this issue I came to know that between the subscriber also we need these opens.
1 question,
how would I verify the port is open from CUCM node to the other CUCM node.
as such from windows we do telnet 10.X.X.X  8500
Thanks Aman [+5]Yosh
Thanks Aman [+5]
Yosh
HTH Regards, Yosh
699
