CUCM 9.X integration with ARC 6.X
niterid3r
We are planning to install ARC in our environment. Just wondering if anyone has a good configuration guide to use as a reference on how to integrate it with CUCM 9.X
Documents are available here: http://www.arcftp.com/ProductRelease/Cisco/Release_6.0/V6.0.0_Arc_Premium_Edition/
Bear in mind it's quite complicated, the interface is tricky even if you know it well, and technically an ARC system should only be installed by an accredited engineer to maintain support etc.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
5 Replies 5
Maheshwar Tayal
Level 4
Level 4
Here you go, it is for attendant console 9.x; same principal should apply
Aaron
Thanks guys:)
No problem!
Please remember to rate helpful responses and mark threads as 'answered' when appropriate to highlight useful content..
Aaron
Just rated then.
Is it possible to have your input on my below post?
https://supportforums.cisco.com/discussion/12277951/cucm-integration-legacy-pbx
thanks
