Community Member
CUCM 9.X integration with ARC 6.X
We are planning to install ARC in our environment. Just wondering if anyone has a good configuration guide to use as a reference on how to integrate it with CUCM 9.X
1 ACCEPTED SOLUTION
Super Bronze
HiDocuments are available
Documents are available here: http://www.arcftp.com/ProductRelease/Cisco/Release_6.0/V6.0.0_Arc_Premium_Edition/
Bear in mind it's quite complicated, the interface is tricky even if you know it well, and technically an ARC system should only be installed by an accredited engineer to maintain support etc.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Here you go, it is for
Here you go, it is for attendant console 9.x; same principal should apply
Super Bronze
Aaron
Community Member
Thanks guys:)
Thanks guys:)
Super Bronze
No problem!Please remember to
No problem!
Please remember to rate helpful responses and mark threads as 'answered' when appropriate to highlight useful content..
Aaron
Community Member
Just rated then. Is it
Just rated then.
Is it possible to have your input on my below post?
https://supportforums.cisco.com/discussion/12277951/cucm-integration-legacy-pbx
thanks
59
