CUCM 9.x with AA
How can I do basic AA function in CUCM 9.x itself.Like bacd in CME(press 1 enther xxx,press 2 enter yyy,press 3 dial by extensions).What if the extesions is not in cucm directly,but with PBX.it can  works?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: CUCM 9.x with AA
Hi.
I uesed both SIP and H323,  certainly not MGCP
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi.
CUCM does not have an embedded IVR feature but it can be done using Unity Connection, UCCX or Auto Attendant on a Voice gateway.
The destination could be also an extension on a remote PBX.
Carlo
thx!
How about I use CME with BACD,and put the extensions in cucm and remote pbx,is this possible?
If not possible,just mean CUC or UCCX is necessary,right?
Hi.
With CME is possible defining Hunt groups with destination numbers and than create dialpeers poiting to CUCM or other pbx.
Carlo
R1(config)#ephone-hunt 2 sequential
R1(config-ephone-hunt)#pi
R1(config-ephone-hunt)#pilot 3000
R1(config-ephone-hunt)#li
R1(config-ephone-hunt)#list 2001
Number 2001 is not a normal ephone-dn or a *.
R1(config-ephone-hunt)#list 2005
There is an error when input the extension(2001) was registered with cucm,is there a command can make it?and there is no problem when  extension(2005) was registered with cme.
Hi.
What I meant was in application configuration, define as aa-hunt option a number defined or in cucm ( which could be an hunt group or ip phone extension) or as number on an external pbx.
Eg.
application
param aa-hunt 1 5700
param aa-hunt 2 5800
5700 and 5800 could one of the above mentioned destination.
members of an hunt group on CME can be local defined extensions
Carlo
It seems also didn't works.when I call 5000,and press 1 or 2,wait 1min,it redirect call to voicemail number (2006) that configured in application .not redirect to cucm number 8000 or 2001.
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
  param number-of-hunt-grps 3
  paramspace english index 1
  param dial-by-extension-option 3
  param handoff-string aa
  paramspace english language en
  param aa-pilot 5000
  paramspace english location flash:
  param second-greeting-time 30
  param welcome-prompt _bacd_welcome.au
  param call-retry-timer 10
  param voice-mail 2006
  param max-time-call-retry 60
  param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
  param queue-len 2
  param aa-hunt10 2002
  param aa-hunt1 8000
  param aa-hunt2 2001
dial-peer voice 2000 voip
destination-pattern 2...$
session target ipv4:142.100.64.11
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 8000 voip
destination-pattern 8000
codec g711ulaw
no vad
dial-peer voice 5000 voip
service aa
destination-pattern 5000
session target ipv4:142.100.64.254
incoming called-number 5000
dtmf-relay h245-alphanumeric rtp-nte
codec g711ulaw
no vad
The CME BACD is only supported and meant to work with CME, if you want an AA for CUCM, you need to use CUC, UCCX or build your own TCL AA script for the GW.
java
if this helps, please rate
www.cisco.com/go/pdi
CUCM 9.x with AA
Hi.
Can you please send the output of a debug voip application script during a call to the application?.
Carlo
this is the all debug info from the debug voip application scrip command.
CUCM 9.x with AA
Hi.
What is destination 2001? (Hunt Pilot on CUCM, IP Phone extension)
Can you hear MoH during waiting?
I reproduced your config in a Lab, and it works with a CUCM Hunt Pilot --> Hunt List -->> Line Gorup (Top/Down Algorithm)
Let me know.
Carlo
2001 is extenstion number on cucm and I can hear moh during waitting,then "all agents are currently busy......")
And also press 1 to pilot number 8000 on cucm was the same situation.Directly call 2001 or 8000 was successful.can you give your cme config to me.and let me try it.
Hi.
This is my config.
application
  paramspace english index 0
  param number-of-hunt-grps 5
  param dial-by-extension-option 1
  param max-time-vm-retry 2
  param aa-pilot 9391
  param max-extension-length 5
  param second-greeting-time 60
  param call-retry-timer 5
  param voice-mail 9999
  paramspace english prefix en
  param max-time-call-retry 600
  param service-name queue2
service queue2 flash:app-b-acd-3.0.0.2.tcl
  param aa-hunt5 9396
  param aa-hunt9 9397
  param aa-hunt2 9393
  param queue-manager-debugs 1
  param aa-hunt3 9394
  param queue-len 30
  param aa-hunt4 9395
  param queue-cme-debugs 1
dial-peer voice 6931 voip
description IVR Pilot
service aa
destination-pattern 9391
session target ipv4:10.10.10.1
incoming called-number 9391
voice-class codec 1
no vad
dial-peer voice 93 voip
description To Groups
destination-pattern 939.
session target ipv4:10.10.10.10
codec g711ulaw
no vad
Carlo
which protocol you're using? i change my vg protocol to h323,and pots interface for pstn incoming call aa pilot number 5000.then all the needs can be achieved.
Hi.
Carlo
483
