CUCM 9.x with Gateway - Troubleshoot call leg
Guys,
We have a CUCM 9.x at a main site (Site-A),  with a h.323 Gateway.
The h.323 Gateway have a Sip Dial-peer with another cisco pbx in another Country (Site-B).
In the past, people at Site-B used to called 816XXX to reach Site-B devices, and People in site-A can dial 83XXXX to reach people at site-B.
I know that some change occured in the last two weeks, since that it longer work for inter-site call.
I know that the IOS of Site-A has been updated to a 15.1   ( BUT we did add the IP address truested command to trust all PBX )
But still it's not working..
I did a debug voip dialpeer,  and I would like to have your opinion
When user from Site B dial : 816999
It’s going well to our router at Bellevue, as expected
040331: 5d10h: //-1/856FEA4E80C4/DPM/dpAssociateIncomingPeerCore:
   Calling Number=83644, Called Number=6999, Voice-Interface=0x0,
I see there is a successful match with dial-peer 6999
040341: 5d10h: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=6999
This dial-peer 6999 point to Call Manager
dial-peer voice 6999 voip
description Outgoing to CUCM
destination-pattern 6...
session target ipv4:10.AA.XZ.ZZ
dtmf-relay h245-alphanumeric
And one have a recommendation ?
Debug the calls and check the
Debug the calls and check the whole config, I've seen many cases in which more than one person had access to CUCM/GW, and changed something without telling anyone else.
java
if this helps, please rate
www.cisco.com/go/pdi
For that specific scenario,
For that specific scenario, Do you recommend any other command to debug than
debug voip dial-peer
ps : The Inbound CSS of the Gateway On Call Manager side reach the Partition extension in the actual scenario
Yes, debug DP doesn't give
Yes, debug DP doesn't give anything beyond the fact you're matching a DP or not.
debug voip ccapi inout
java
VIP Super Bronze
You will need to see in depth
You will need to see in depth into the h225 and h245 signalling as well ass the CCAPI process..
You should do this
debug h225 asn1
debug h245 asn1
To capture all of these logs..you need to properly setup your gateway as follows
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
<Enable debugs, then test again.>
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
show logging
You can attach the logs here in a text file
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
83
