CUCM 9.x with outside IVR
OK, so we are having CUCM 9.x and 2951 router with SIP trunk to PSTN. Router is set as h323 gateway for CUCM... Pretty simple configuration, nothing fancy, and everything is working as it should, but one thing.
After we are call someone outside who is using some sort of IVR(lets say you call your ISP, and first thing you get is IVR saying press 1 if you want to talk with sales, press 2 if you want to talk with IT...), connection is established, but after it, telephone doesn't react whatever number you are pressing. So after I get the message to press 2 to talk with IT for example, I can press 2 all day long, nothing would happen, I would still have innitial dialog...
Does anyone knows what is the problem with this, and where in configuration I could change it?
Hall of Fame Super Silver
Sounds like DTMF mismatch, first question why are you using H323 between CUBE and CUCM if you have a SIP trunk? Do yourself a favor and convert it to SIP and then standardize on one Dtmf-relay method.
HTH,
Chris
Mostly because I'm way over my head in voice over IP, so I used some similar configuration as my guide when I started, and there was h323 between CUCM and CUBE even though they too have used SIP trunk...
Also, have looked about similar dtmf mismatches, and what frightens me is that they were also using 7942 phones... But that was 3 years ago, and should've been solved by now.... Anyhow, big thanks on your response, helped me know where to look at I will try something tomorrow(looks like I have missed dtmf relay in one dial peer while configuring), and hopefully it will work.
When you get a chance also post your configuration, one thing to keep in mind is that all call flows use 2 dial peers (inbound and outbound) if you do not have an explicit inbound dial peer configured with proper dtmf method then hidden dial-peer 0 is used which is known to mess with things like this.
HTH, please rate all useful posts!
Chris
so, the story is still the same, and im out of the ideas... one important note though. after we get connected and hear "welcome to call center of....", after pressing a number, we can hear a sound of number being pressed, but we are not seeing anything on phone display ! all the phones are 7942.
this is what debug says in the moment when we press the number(i have upload of whole debug ccsip, ccapi and rtp session, but not sure how to upload it):
*Dec 10 17:21:38.442: //7015/80F4757E4600/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x1B68
*Dec 10 17:21:38.442: //7015/80F4757E4600/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
*Dec 10 17:21:38.518: //7015/80F4757E4600/CCAPI/cc_api_call_digit_end:
*Dec 10 17:21:38.518: //7015/80F4757E4600/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
i would post whole configuration, but again, i dont see where can i upload file, so here are important parts:
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 192.168.168.0 255.255.255.0
  ipv4 10.0.0.0 255.0.0.0
  ipv4 10.0.0.2
  ipv4 10.27.2.0 255.255.255.0
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  no h225 timeout keepalive
  h225 id-passthru
  call preserve
  h245 passthru tcsnonstd-passthru
  h245 passthru all
sip
  header-passing
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 5 g723ar53
codec preference 6 g723ar63
--More--                            codec preference 7 g723r53
codec preference 8 g723r63
voice class h323 100
  h225 timeout tcp establish 2
  h225 timeout setup 2
sccp local GigabitEthernet0/1
sccp ccm 10.27.2.12 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 3 register my_trans
associate profile 2 register my_mtp
associate profile 1 register my_conf
dspfarm profile 3 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 3
associate application SCCP
--More--                           !
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729ar8
codec g729abr8
codec g722-64
codec g711ulaw
codec g711alaw
maximum sessions 3
dspfarm profile 2 mtp
codec g711alaw
codec pass-through
maximum sessions software 100
dial-peer voice 10 voip
description TELEKOM_KA_CUBE
service skripta
session protocol sipv2
session target sip-server
incoming called-number (hidden)
voice-class codec 1 offer-all
voice-class sip profiles 1
no voice-class sip encap clear-channel standard
dtmf-relay rtp-nte sip-notify
no vad
dial-peer voice 20 voip
description CUBE_KA_TELEKOM
translation-profile outgoing 1
preference 1
destination-pattern .T
voice-class sip dtmf-relay force rtp-nte
no vad
--More--                           !
dial-peer voice 30 voip
description CUBE_KA_CUCM
translation-profile outgoing 2
destination-pattern (hidden)
session target ipv4:10.27.2.12
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 40 voip
description CUCM_KA_CUBE
incoming called-number .T
no vad
dial-peer voice 50 voip
description OD_CUBE_KA_CUCM
destination-pattern 75..
no vad
________________________________________________________________________
i have tried different scenarios with dtfm-relay rtp-nte on dial peer 30 and 50, still nothing...
166
