Community Member
Cucm add line and speed dial on 40 phones
I have cisco cucm version 8, I would like to know the steps I would take to change the phone Template as well as the add the same two speed dials on 40 phones. This phones are 7961 which have six buttons two lines which would stay the same on 40 phones but I will need to change two buttons for speed  dials and configure the same speed dial on all 40 phones.  How can change the phone template and add the speed dials on all 40 phones at once instead individual?
Hall of Fame Super Silver
Re: Cucm add line and speed dial on 40 phones
Export the phones, adjust the settings and reimport.
Chris
Community Member
How do you that, do use bat tool?
Yes, you use BAT to export the current config, add all you need, and import the new file to update the config.
java
if this helps, please rate
www.cisco.com/go/pdi
99
