CUCM Admin Security Token?
I'm reviewing a BoM and I am confused by this item:
KEY-CCM-ADMIN-K9=  CUCM Admin Security Token, 4.3, 6.0, or Newer, CoO Israel
Googling this comes up with info on encrypting connections, etc. but I can't find this particular item.
Does anyone know what this is and why it might be needded on a CUCM/UC rollout?
1 REPLY
Re: CUCM Admin Security Token?
Those are used when you need to enable authentication and encription for signaling and/or media.
They are required to use the CTL client.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1283
