06-17-2008 05:38 AM - edited 03-15-2019 11:19 AM
Is anyone using this integration and why, what advantages are there, what is the drive to AD except the telephone directory is in synch ? With Extension mobility if you use numbers then post AD you have to select the Disable Alphanumeric Login so an EM user can still log in as before. Is adding users via AD the main reason and if so what do you lose on CUCM is all the administration now with AD so the IPT guys lose control many thanks
06-17-2008 09:48 AM
the main advantage is that if you already have your directory populated there is no need to re-create all in the CUCM server
javalenc
if this helps, please rate
06-17-2008 10:37 AM
Another great reason for using this feature is integrated authentication. If your end users use the CCMUser page this would allow them to use their AD credentials to access the system.
10-01-2008 08:29 AM
I can't seem to find the way to enable Integrated Authentication in 6.1.2. I thought it was a Service or Enterprise parameter, but I can't find it for the life of me.
Any tips?
