CUCM and CUEAC call reporting question
Customer has Enterprise Attendant Console 8.6 and CUCM 8.5.  Is there anyway using the CUCM CDR records to report on calls to different CUEAC queues?  Right now, when you look at the CDRs, it only shows the CTI ports that the server is using and operator extensions.  It does not show the CTI Route point extension so there is no way to tell what queue the call came in on.  I realize there is some call reporting built into CUEAC that would probably do what they want, but the customer purchased ISI call reporting software and really want to use that product.  Was hoping someone had hit this issue before and came up with a creative workaround.  Any help would be greatly appreciated, thanks.
Brian
Everyone's tags (4)
466
