CUCM and H323 gateway-Cause i = 0x80A6 - Network out of order
I cant get calls into the CUCM from a H323 gateway. Incoming external calls here out of service message or Number Unobtainable. I've attched logs if anyone can help?
Rich
1 ACCEPTED SOLUTION
Green
Rich,
To sum up so far.
Call comes in on BRI  - OK
Q931 set up received for Called number 562982 - OK
562982 is translated to 52982 - OK
Matches dial peer 101 fails to connect
retries on dial peer 100 and again fails to connect.
IP addresses seem OK.
CSS on gateway is good
I can only assume that the it is the H323 protocol from the gateway to the CUCM that is failing.
Is ther any firewall etc between the gateway and the CUCM
H323 needs to set up a TCP session on port 1720 to pass the signalling information at the start of the call.
We may now need a packet trace from the routers IP port etc to further understand what is going wrong.
Alex.
Regards, Alex. Please rate useful posts.
Green
Rich
From your incoming call the Q931 setup shows:-
Called Party Number i = 0x81, '562982'
I can not see any VOIP dialpeer to match this
destination pattern
the nearest VOIP dialpeer may have a typo
dial-peer voice 52982 voip
preference 1
destination-pattern 52982
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.0.150
dtmf-relay h245-alphanumeric
no vad
Can you ammend this to :-
dial-peer voice 562982 voip
preference 1
destination-pattern 562982
voice-class codec 1
voice-class h323 1
no vad
Alex
Re: CUCM and H323 gateway-Cause i = 0x80A6 - Network out of orde
Hi Alex,
Thanks for reply. I should've attached the full config as it shows the Translation Rules. See below.
Can anyone help?
voice translation-rule 2
rule 1 /^56/ /5\2/
rule 2 /^6/ /5/
rule 3 /2/ /52/
voice translation-rule 3
rule 1 /^1\(.........$\)/ /01\1/
rule 2 /^2\(.........$\)/ /02\1/
rule 3 /^7\(.........$\)/ /07\1/
rule 4 /^8\(.........$\)/ /08\1/
rule 5 /^4\(......$\)/ /01914\1/
rule 6 /^2\(......$\)/ /01912\1/
voice translation-rule 6
rule 1 /^[1-9]/ /90\0/ type international international
voice translation-rule 7
rule 1 /^1/ /901/
rule 2 /^2/ /902/
rule 3 /^3/ /903/
rule 4 /^4/ /904/
rule 5 /^5/ /905/
rule 6 /^6/ /906/
rule 7 /^7/ /907/
rule 8 /^8/ /908/
rule 9 /^9/ /909/
voice translation-profile INCOMING
translate calling 7
translate called 2
voice translation-profile OUTGOING
translate called 3
voice-card 0
dsp services dspfarm
interface FastEthernet0/0
ip address 192.168.178.66 255.255.255.192
ip pim dense-mode
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.178.66
interface FastEthernet0/1
no ip address
duplex auto
speed auto
no keepalive
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
control-plane
voice-port 0/1/0
translation-profile incoming INCOMING
compand-type a-law
cptone GB
description ISDN2 .......... lines 1+2
voice-port 0/1/1
compand-type a-law
cptone GB
description ISDN2 .......... lines 3+4
ccm-manager music-on-hold
mgcp fax t38 ecm
dial-peer cor custom
dial-peer voice 999 pots
destination-pattern 999
port 0/1/0
forward-digits all
dial-peer voice 9991 pots
port 0/1/1
forward-digits all
dial-peer voice 112 pots
destination-pattern 9112
port 0/1/0
forward-digits 3
dial-peer voice 1121 pots
port 0/1/1
forward-digits 3
dial-peer voice 9999 pots
destination-pattern 9999
port 0/1/0
forward-digits 3
dial-peer voice 99991 pots
port 0/1/1
forward-digits 3
dial-peer voice 100 voip
preference 2
destination-pattern 52...
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 101 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.203.20
no vad
dial-peer voice 1 pots
translation-profile outgoing OUTGOING
preference 3
destination-pattern 0T
translate-outgoing called 10
incoming called-number .
fax rate disable
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 11 pots
preference 4
fax rate disable
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 9 pots
preference 1
destination-pattern 9T
fax rate disable
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 91 pots
preference 2
fax rate disable
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 2 pots
destination-pattern 2......
fax rate disable
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 21 pots
fax rate disable
direct-inward-dial
port 0/1/1
forward-digits all
preference 1
voice-class codec 1
voice-class h323 1
no vad
Green
Rich,
I can now see that the i/c call for 562982 is being translated to 52982 and is
matching both dial peers 101 then 100, both fail to pass the call.
Can you look at the call manager H323 gateway serttings.
In the inbound call section what valueis set for the number of significant digits
It should be set to either "ALL" or "5"
Also is the CSS going to find a partitionwith the device with DN 52982
Alex
Hi Alex,
Regretably I've already checked that. 5 digits and the CSS can see the phones partition.
I was wondering if the dial peers were OK?
Rich
Green
Rich,
The dial peers that are being matched are :-
preference 2
voice-class codec 1
voice-class h323 1
no vad
preference 1
voice-class codec 1
voice-class h323 1
no vad
Is there definitely ip connectivity between this router and these 2 ip address
1st choice CUCM
192.168.203.30
2nd choice CUCM
192.168.0.150
Hi Alex,
I've successfully pinged all CUCMs. Any ideas?
Rich
Green
Rich,
I know this is a bit basic but can you confirm that the H323 gateway in CUCM is
192.168.178.66
Can you also click on reset & RESET the H323 gateway on CUCM and retest.
Alex
Hi Alex,
I've deleted the gateway in CUCM and re-added-same issue
Rich
Green
Rich,
To sum up so far.
Alex.
Sorted!
Something was blocking port 1720. The gateway had two dial peers pointing to two CUCM's. These CUCMs have port 1720 blocked somewhere. The third CUCM wasnt being blocked but wasnt on gateway-added it=working straight away. Need to track it down but its working! Thanks Alex.
Rich
Hi,I have CUCM 10.5.1 BE6000
I have CUCM 10.5.1 BE6000 on UC220 and have 2921 H232 voice gateway.
i have error "Network out of order" and unable to make international calls. ISP saying that their end is fine.
Please help me to resolve the issue.
Thank you in advance.
Hi Rizwan.What kind of pstn
Hi Rizwan.
What kind of pstn are you using? (E1 T1 Trunk Sip )
Please let me know.
regards
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo, I am using E1 line.
Hi Carlo,
I am using E1 line.
Please advice.
Hi Rizwan.Can you please send
Hi Rizwan.
Can you please send a debug isdn q931 while calling an international number?
Carlo
here it is.
here it is.
Hi Rizwan.You are sending a
Hi Rizwan.
You are sending a numbering plan "unknown" to your TSP for international calls and this could be the reason.
Try to apply a numbering plan "international" to the Route Pattern on CUCM matching international calls, or you can do it on VG by configuring a translation rule than a translation profile and applying it to your dial-peer matching international calls:
voice translation-rule 10
rule 1 /^00/ /\0/ type any international
voice translation-profile OutInternational
translate called 10
dial-peer voice 10 pots
destination-pattern 00T
translation-profile outgoing OutInternational
port X/X/X:15
forward-digits all
Carlo
Alex,
Are there any services on CUCM that may need to be enabled causing this issue?
Rich
Green
Rich,
I think that if Call manager service is running then it should be able to process H323.
You reckon that the 3rd server was Ok, is that in the same cluster as the failing pair.
Alex
7872
