02-13-2012 09:29 AM - edited 03-16-2019 09:33 AM
A client has CUCM 5.1 with 2811 MGCP gateway (IOS 12.4). They have planned to upgrade to CUCM 8.6 in the near future. But they got call quality issue since last week and we narrow down it would be issue related to the gateway.
My questions:
1) If we replace the 2811 gateway with a new 2911 (IOS 15.1), can the new 2911 work with CUCM 5.1?
2) If IOS 15.1 is not compatible with CUCM 5.1, may I downgrade IOS 15.1 to 12.4 on 2911? Will the licenses with 2911 be lost after downgrade?
Thanks.
Michael
Solved! Go to Solution.
02-13-2012 09:41 AM
Short answers:
1. No, not with MGCP, you will either have to upgrade CUCM or convert to H323
2. No, G2 routers 29XX require 15.0+ IOS
The bigger question here is why do you assume replacing a platform is going to resolve your QoS issues, that is very unlikely, can you tell us how did you come to this conculsion?
Chris
02-13-2012 09:43 AM
We went through this about 2 years ago. Your best best is going to be to upgrade to CUCM 7.1.5 at the lowest.
If memory serves me correctly 2900s are not officially supported on 12, in conjunction with CUCM, TAC would be best to confirm.
With regards to the licenses they are stored separately from IOS
02-13-2012 10:23 AM
Looks like you do not have "network-clock-select" which is needed to properly assign clocking order, this is a very common omision that results in the issue you are describing. I suggest you add it and see if it resolves your issue.
HTH,
Chris
02-13-2012 09:34 AM
Use the below link for your listed queries,
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Hope it helps,
Anand
02-13-2012 09:41 AM
Short answers:
Chris
02-13-2012 09:53 AM
Thanks Chris for your answers and questions.
The issue is PSTN call can't connected or static noise. We see errors when show controller T1 (44 or 45 slip seconds every data interval) . We have Telco tested the T1 line on site, no errors on network side. Then we replaced the T1 card, doesn't help either. So we think it might be something with gateway itself. I will test the T1 with a new 2911 router this afternoon.
Please share your any different thoughts.
Michael
02-13-2012 09:57 AM
It's possible there are bad DSPs on your router, but the likelihood is small.
How many T1 lines do you have on this router, how is clocking configured?
Do you have similar config:
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
what does "show network-clocks" show?
Chris
02-13-2012 10:28 AM
Thanks.
Just like to confirm. Is the following configuration required even though there is only on T1?
02-13-2012 10:29 AM
Correct.
Chris
02-13-2012 10:16 AM
It's a small site. There is only one T1. How can I verify if there are bad DSPs?
"network-clock-participate wic 0" is configured.
voice#show network-clocks
Network Clock Configuration
Priority Clock Source Clock State Clock Type
10 Backplane GOOD PLL
Current Primary Clock Source
02-13-2012 10:23 AM
HTH,
Chris
02-13-2012 10:29 AM
Sorry,
Just like to confirm. Is the following configuration required even though there is only one T1?
02-13-2012 09:43 AM
