CUCM announcements configuration
i'm configuring a cluster of 3 CUCM 7.1.3 and i'd like to implement announcements. I started the IP Voice media streaming service on the 2 subscribers and i have got 2 annunciator correclty registered. I read the types of announcements supported by CUCM but i'm still asking 2 questions:
- the announcements are active as soon i activate the IP Voice media streaming service, but how can i configure them ? Only in the "Route Pattern" page in the "block this pattern" drop down menu or in other place also ? The official documentation is not clear about it
- i'd like to choose when activate an announce: for example when a DN calls an unregistered or non-existent DN. It's possible to do that ?
Thank you,
Roberto
1 ACCEPTED SOLUTION
Re: CUCM announcements configuration
The announcements are active as soon as you enable the IPVMS and get the ANN's registered.  You cannot configure/modify the actual annunciator prompts in the appliance model versions of CUCM.  You can cause an annunciator message to be played using a Route Pattern (in the way you suggest) or by using a translation pattern (in a similar fashion).  The unallocated/unassigned message is "automatically" available for stations registered to your CUCM.  Meaning, you don't need to configure it.  Well, aside from making sure that the annunciator media resource is exposed to the phone/gateway via the media resource group list configuration parameters in your cluster.  If you do not place the ANN's in a MRG then you should be fine.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
HTH.
Bill
You need CUCM 8.X to do that.
Announcement Configuration
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi William and Javalenc,
thank you for reply, i find method to select system messages by creating CSS containing first partitions linked to route patterns blocked and then a partition linked to a route pattern allowed and containing all dialable external numbers (0.!). So, for each pattern, i can select "block this pattern" and then the error message. But i noticed that not all system message are played: for example "call reject" message is never played while "Precedence Level Exceeded" is played correctly.
Consider that i loaded (on all the members of the cluster) the locale Italian File "cm-locale-it_IT-7.1.3.2000-1.cop.sgn" and all the system messages should be present. Maybe i forgot something ?  Could be a specific reason for some system messages not played ? Maybe i must load the file "cm-locale-combined_network-7.1.3.2000-1.cop.sgn" also ?
Thank you,
Roberto
P.S. how can i rate your replies ?
2847
