Community Member
CUCM as Backup
HI
I have a question , i have a cluster for 2 Cisco call manager and my cluster is working very fine. I purchased a 3rd CUCM server  can i use it as a backup server and if yes ,is this need any licenses because i donot have budget to purchase?.
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: CUCM as Backup
Email licensing@cisco.com for free node license.
Chris
Community Member
CUCM as Backup
I need to mention that i mean by backup , that when my cluster is down my backup server can serve my IP Phones.
CUCM as Backup
What do you mean you purchased 3rd CUCM? As of version 8 or something like that CUCM nodes are free.
Any device on CUCM can communicate with 3 CUCM servers, so yes you can definitely use it as another backup in your cluster.
HTH,
Chris
Community Member
Re: CUCM as Backup
1- I have CUCM MCS v8.6 as a H/W for 3 servers and i enabled cisco call manager on PUB and 1 X SUB, but the license only covered 2 servers . My question regading the 3rd server , can i use it as a backup without license or any thing else ?. I need to make 3rd server to be used ,so i have to disable Call manager service from Pub to allow the other two servers work as subscribers?.I need also to mention that when i tried to enable call manager on 3rd server , i got that there is no licenses.So on my group only 2Xservers (PUb and Sub)
thanks
Re: CUCM as Backup
Chris
112
