CUCM BE 6K with rehosted license and no service
Hi All,
I´ve installed a rehosted license for CUCM BE 6K and all phones go registering and then unregistering. I´ve already restarted both Publisher and Subscriber after intalling the new license.
Please let me know if something more is missed.
P.S. Attached two images about that inside Licensing> License Usage Report> Unassigned Devices
1 ACCEPTED SOLUTION
Re: CUCM BE 6K with rehosted license and no service
Have you tried deleting CUCM from ELM and re adding it??
Does licenses show correctly on ELM?
java
if this helps, please rate
www.cisco.com/go/pdi
java
Hi JaVA,
We decided to open a TAC case so they required to sent them a SDL Trace from a 6945 IP Phone, they found in Bug Toolkit the following: CSCua81567.
Workaround was made and all IP Phones came registered.
Thanks a lot for your support anyway.
155
