Community Member
CUCM-BE 7.1.3 - Can't access Cisco Unity Connection
I have CUCM-BE 7.1.3. I can't access Cisco Unity Connection and I receive the following error :
HTTP status 500
type: Exception report
message:
description: The server encountered an internal error () that prevented it from fulfilling this request.
exception:
javax.servlet.ServletException: com.cisco.unity.datatools.DataException: unable to get authentication transfer object
org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:516)
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:423)
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:226)
Server was restarted, but I can't access Cisco Unity Connection.
Re: CUCM-BE 7.1.3 - Can't access Cisco Unity
Was this working before or is this a new install?
A lot of people search the CSC for help on similar problems so please refer to the products by the correct name to avoid confusions, this is Unity Connection, not Unity.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Re: CUCM-BE 7.1.3 - Can't access Cisco Unity Connection
This working before.
Sorry for wrong thread name. The thread was edited.
Any changes prior to the problem?
java
java
Community Member
I just sync user for voicemail. When I try to access Cisco Unity Connection again, HTTP status 500 error message displayed.
Riko
When you say sync users for VM, I assume you mean LDAP. So, can you access CU Admin using the application administrator user you created during installation (ex: ccmadministrator, cuadministrator...people use various names for the app ID).
Hailey
Please rate helpful posts!
Community Member
No... I am synch users for user who change DN or create a new user for VoiceMail. I created in CM>User Management>End User.
I have access CU Connection  Administration using application administrator user that I created (ccmadministrator).
620
