CUCM-BE code upgrade
My goal is,
-CUCM 6.0.1 to 6.1.2
-Unity connection 2.0 to 2.1
Can I upgrade each code from CUCM-BE 'OS administration' menu seperately? means upgrade CUCM first and upgrade 'unity connection' from the same menu. Is the CUCM-BE automatically detects the code and upgrade CUCM and 'unity connection' accordingly?
This is critical to me since the CUCM-BE hardware is not hot-pluggable HDD. Please advise.
Thanks in advance,
1 ACCEPTED SOLUTION
Re: CUCM-BE code upgrade
sorry, been very busy lately
the file contains both apps, you're all set with the latest CUCM BE version as far as i can tell
javalenc.
java
if this helps, please rate
www.cisco.com/go/pdi
Exactly but still not clear from the doc and that's why posting again.
the description from this posting is my understanding from the doc but I really want to get clarification.
Please!!
okay... eventually I got the result,
beofore upgrading the CUCM-BE
-CUCM 6.0.1
-CUC 2.0.1
after upgraded the CUCM 6.1.2,
-CUCM 6.1.2
-CUC 2.1.2
I didn't upgrade the CUC yet but why it shows 2.1.2.. is the CUCM includes CUC code by default or still do i need upgrade the CUC now?
Thanks in advance,
javalenc.
java
Excellent. Thanks a lot for your clarificaiton.
150
