CUCM-BE Reporting Ability From Built-In ACD Calls
If a client uses the built in ACD such as longest-idle will the CDR records give info that could be parsed to give generic reports like longest call waiting or any type of ACD reporting capability.
Long story and only need short answer yes or no so I can go to next step but I figured that I would give it a shot! Next step will be UCCx but I need to find this out first.
Thanks in advance!!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CUCM-BE Reporting Ability From Built-In ACD Calls
Hi Daryl,
No ACD reports :(
Cheers!
Rob
1 REPLY
Hi Daryl,
No ACD reports :(
Cheers!
Rob
133
