Cucm bulk administration
I have a cucm ver 8.6
There is a request to create in bulk a devices in the format :
Mac address with remote destination an remote destination profile
I triad number attempts to do so can anyone have idea ?
Sent from Cisco Technical Support Android App
VIP Super Bronze
You'll need to execute a few separate jobs as there is no single job that will do it all.
  • Insert phones
  • Update users (e.g. associate physical phone, set primary extension, enable mobility, set primary device)
    Alternatively, you can use insert phone/user if the cluster is not integrated with LDAP
  • Insert Remote Destionation Profile
Please remember to rate helpful responses and identify helpful or correct answers.
Re:Cucm bulk administration
Thanks on your info .
It's alote to configure .the correct flow is :
Only Device profile / remote dest / remote dest profile / device / users id
I can't do that on 2-3 bulk ?
161
