CUCM business edition 7k
I have 2 new 7k servers
is this will be pre installed ? or I'll deal with it like new C series UCS and use the ova files and install the iso file for cucm then ove and iso file for unity connection
1 ACCEPTED SOLUTION
VIP Purple
Hi Haitham, You an refer the
Hi Haitham,
You an refer the datasheet which says " BE7000 ships with a preinstalled virtualization hypervisor and preloaded software applications that are ready to deploy."
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-7000/data-sheet-c78-730649.html
regds,
aman
VIP Purple
Hi Haitham,
regds,
aman
As Aman says, only ESXi will
As Aman says, only ESXi will be installed, you need to deploy the preloaded OVAs and ISOs for the product install
java
if this helps, please rate
www.cisco.com/go/pdi
43
