CUCM business edition - upgrade to 6.1.2
is the 6.1.2 available for business edition from CCO?
Thanks in advance,
Re: CUCM business edition - upgrade to 6.1.2
If you go to cisco.com and look under downloads you can check all the info you're looking for
Cisco Unified Communications Manager 6.1
http://www.cisco.com/cgi-bin/apps/tblbld/tablebuild.pl/callmgr-61?sort=release
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Is it not impact Unity connection if I upgrade same way to other CUCM platform? I taught there is different code since it contains unity connection.
Thanks in advance,
Hall of Fame Super Red
Upgrading from Cisco Unified Communications Manager Release 6.0(1) to Release 6.1(1a) Using the UCSInstall File
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_1/cucmbe-rel_note-611a.html#wp291021
Upgrading from Cisco Unity Connection 2.0 to 2.1 or Cisco Unified CMBE 6.0 to 6.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_1/211ucrn_be.html#wp48891
there will be some documentation for 6.1(2) on the same
javalenc
java
I want to make clear to not impact the production. please clarify the following,
1. upgrade CUCM part=download CUCM image and upgrade from 'Cisco Unified OS administration' menu
2. upgrade CUCM unity connection part=download Unity connection image and upgrade from 'Cisco Unified OS administration' which is same menu to upgrade the CUCM image.
-->Eventually I need two times upgrading to upgrade CUCM and unity connection both. Am I corrrect?
-->if the above assumption correct, I guess CUCM-BE has two independent partition to running CUCM and Unity connection seperately but provides single interface to manage together.
Thanks in advance,
John
177
