07-31-2009 11:42 AM - edited 03-15-2019 07:10 PM
The client in question is using CUCM 7.0 and has a 7941 IP phone. We've been seeing some strange intermittant behaviour.
When the call is connected it will sometimes be immediately placed on hold and then drop off the phone. The caller will be left on hold but the call has dropped off the phone so the user can't resume the call.
If the caller then hangs up and calls back the call will (usually) connect normally.
I have not been on-site when this occurs but I can be reasonably certain that its not an issue of user error.
08-06-2009 01:46 PM
Try to disable RTCP timer in MGCP using the command âno mgcp timer receive-rtcpâ.
08-10-2009 05:44 AM
Thank you for the reply but the RTCP timer is already disabled
09-02-2009 07:03 AM
Do you have any update on this? Is this still going on? What did you do to solve this?
09-02-2009 12:17 PM
I never tracked down the cause of this issue. I checked back with the user about a week after the initial posting and it had stopped happening. However, we have had similar issues happening with different users in the same organization so I am still looking into the broader issue
