Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
CUCM cannot reset phones or make changes
I have an existing three server cucm cluster 6.1.2
I am unalbe to make any changes to phones, and unable to reset phones. This has worked fine for the last few months.
The license limit was nearly at capacity, so I added 100 DLU's. I was 24 DLU's from the limit, so not sure if that matters. Any suggestions? Replication is showing fine in RTMT, and no other errors are reporting.
Re: CUCM cannot reset phones or make changes
any error messages when you try to make changes??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Actually, yes.
When I try reset a phone, the second small browser window pops up to Reset, Restart or Close the window. After I select Reset then Close, I get a Runtime Error.
Also, when a co-worker logins in to the admin page his fonts will change randomly as he browses.
I assumed this was all related to a windows hotfix pushed to our PC's over the weekend.
first thing i would try would be restart Tomcat to get the CCMadmin right
java
java
Red
Also use RTMT to check the change notification in queue. I'm suspecting this is a "change notification" issue.
Michael
http://htluo.blogspot.com/
Where in RTMT would I look for this notification?
Michael,
You are correct. I contacted TAC and it appears to be a fairly common bug on 6.1.2.
I had to restart CM service on all servers as a work around, but will be upgrading to 6.1.3 shortly to correct.
455
