CUCM Cannot Update Phones
I have been running CUCM 6.1.1.3000-2 for about a month now, and ran into the problem today that any updates that I make to phones will not take effect.
In addition, when I delete a phone, and go as far as a hardware reset (hold down # on startup) the phone will still register as normal.
Phones are registering fine, and are functioning, I just cannot make a change.
I have restarted tftp, and dbl. This is a single server deployment, so all the phones are registered to the only PUB.
What else should I look at?
1 ACCEPTED SOLUTION
Re: CUCM Cannot Update Phones
we restarted RIS, DBL, ACISCODB and TOMCAT. at the time the guy was not willing to restart CCM, so that's the only one we could not try. later on during the night he rebooted the server but the traces were not enabled so we could not get a root cause
you can try those services, maybe with you they do the trick
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
i saw a similar issue like this on which the GUI would show the changes but the DB would not change (we confirmed what was on the trace using QRYs in the DB directly and they matched), a reboot cleared the issue
javalenc
java
Jaime,
Thanks for the response. I was afraid of that.
Did you try restarting other services? I would like to avoid a reboot as this is a single ccm deployment, but if that's the only option, I'll give it a shot.
Jeff
javalenc
java
I went ahead and rebooted. I wish I knew of another way to handle it, should it come up again, but it least that resolved it this time.
We're on 6.1.1.2000-3 here and are seeing the issue today (I spent the whole day thinking I was finally losing my mind). Did anybody find a root cause or service that can be restarted as opposed to the whole server? Is there an open bug on this?
Tx.
i believe so far no one has had a TAC case and provided all the info to review so no bugs for this
java
java
137
