07-30-2013 05:33 AM - edited 03-16-2019 06:37 PM
Is it possible to resize my Call Manager cluster to get ride of some extra Vitrual Machines(VM) (This is all running on Cisco UCS)
for example (current cluster)
Phones = 10,000
Using 2500 (larger vDisk),
4 GB RAM
1x80 Gb
1 vNic
4 subscribers each with 2,500
2 subscribers for failover (1:2)
and
1 Publisher
1 Standalone TFTP
is it possible to resize the CUCM to elimint some of the CUCM VM's
for example
2 subscriber with 7,500 capacity (Call Processing Agent)
1 publisher
1 Standalone TFTP
(This would save me alot of RAM and when failure occures in 1 of the subscribers 75% phones will be preserved)
Originaly it was 8 serves and now 4 server's
OR
for example
4 subscriber with 2,500 capacity (Call Processing Agent)
and 1 extra subscriber with 7,500 capacity (eliminating 2 subscriber for failover)
1 publisher
1 Standalone TFTP
This would save some RAM on the vitrualization side since I dont need to use 2 vm's as backup instead only 1 vm with a little extra RAM
Originaly it was 8 serves and now 7 server's
My Main question is Can I Resize my CUCM's after they have been fully configured?
Thanks.
Solved! Go to Solution.
07-30-2013 07:17 AM
You can resize CPU and RAM, but not disk space, so if the different OVAs require different disk space allocation you would need to re-install the app. This is described here:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#Resize_Virtual_Machine
HTH,
Chris
08-17-2013 05:57 AM
You cannot have a mega cluster or super cluster if it has not been validated and approved by cisco as there is a separate team that supports them, you cannot just create one and expects us to support it.
07-30-2013 07:17 AM
HTH,
Chris
08-17-2013 12:43 AM
One more questions regarding Clusters
a.) In cisco srnd is states that a Cluster can have max 20 servers and only 8 running CUCM Service's.
Are they counting the backup servers running CUCM Service with a 1:1 model
for example I have 20,000 Phones and I'm using 2,500 OVA
And I'm running 8 Primary subsribers in different cucm groups with each one idle backup server, does this bleed into aMega-Cluster or is this a regular Cluster
b.) What the real difference between a normal Cluster and Mega Cluster since they both have max call processing servers listed as "8". ?
c.) Is there away to find out if a cluster is a megacluster?
d.) If I use a 2:1 model in Mega cluster, will there be any technical issue's or/and void cisco support.
08-17-2013 05:57 AM
