CUCM CDR Reports don't show called number before being translated
Hi there,
by any chance you know of any way to bypass this limitation from CUCM? - I have been looking everywhere with no luck. when we download the CDR reports from CUCM it comes with all the translated numbers instead of the Original Called Number.
Please help!!!
1 ACCEPTED SOLUTION
Hi Andres
Based on the below document
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_5_1/cdrdef/cdradmin/cdrfdes.html
originalCalledPartyNumber
Text String
This field specifies the number to which the original call was presented, prior to any call forwarding. If translation rules are configured, this number reflects the called number after the translations have been applied.
This field represents a numeric string of up to 48 characters that can be either digits or a SIP URL.
Default - Empty string " ". If destination cannot be reached, this field stays empty.
Please rate all useful information
Hi Andres
Text String
This is a very old question,
This is a very old question, but time and experience have shown me that there are many wasy to skin a cat.
This can be accomplished in many ways and even without applying translation patterns in CUCM and then define all DIDs into the CUBE gateway which was my case. This client has 500+ DIDs but this can be accomplished in new IOS releases where a new Dial-Peer that looks at a list of DIDs in flash can be used, very little maintenance and overhead.
Create a file with e164 numbers and call it e164-pattern-map.cfg
the file will contain the following:
3051111111
3051111112
9541111212
8912221212
Save the file in Flash, and the following is how you call it:
voice class e164-pattern-map 100
 url flash:e164-pattern-map.cfg
dial-peer voice 100 voip
 destination e164-pattern-map 100
 session target ipv4:x.x.x.x
216
