CUCM change application login
Dears,
Kindly how I can change the application login username/password, advise?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_5_1/cli_ref_851.html#wp222740
utils reset_application_ui_administrator_name
This command resets the application user interface administrator name.
Command syntax
Parameters
None
Requirements
Command privilege level: 0
Allowed during upgrade: Yes
utils reset_application_ui_administrator_password
This command resets the application user interface administrator password.
Command syntax
Parameters
None
Requirements
Have fun!
Re: CUCM change application login
Thanks for the steps, kindly can I create another application account to the already active one?
From CLI?
You can of course do this in the GUI.  Just login in with the one accoutn create a user and assign them the correct group which has the admin roles.
Please rate post if you found helpfull.
156
