CUCM Cluster NodeId
I have a couple of questions regarding CUCM cluster NodeId. This is the NodeId which is used in CDR file name (see http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/cdr-defs/cdrprocess.htm).
Question 1:
Is this the CTI ID from Web UI / System / Cisco Unified CM - section Server Information ?
Question 2:
Is this the NodeId which can be retrieved using AXL from table ProcessNode, column NodeId (for pkid 0000000-1111-000...)?
Question 3:
Is there a way how to retrieve this NodeId using SNMP?
Thanks, Jan.
Everyone's tags (3)
1 REPLY
CUCM Cluster NodeId
I think this OID is what you are looking for
Type:    OBJECT-TYPE
OID:    1.3.6.1.4.1.9.9.156.1.1.2.1.1
Full path:    iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).cisco(9).ciscoMgmt(9).ciscoCcmMIB(156).ciscoCcmMIBObjects(1).ccmGeneralInfo(1).ccmTable(2).ccmEntry(1).ccmIndex(1)
Module:    CISCO-CCM-MIB
Parent:    ccmEntry
Next sibling:    ccmName
Numerical syntax:    Gauge (32 bit)
Base syntax:    Unsigned32
Composed syntax:    CcmIndex
Status:    current
Max access:    not-accessible
Description:    An arbitrary integer, selected by the local CCM,
     which uniquely identifies a CallManager in a call manager
     cluster.
400
