CUCM configuration file
alex goshtaei
Hi All,
is it possible to configure CUBE, backup from configuration, then restore to CUCM? both are using the same version.
any suggestion would be appreciated.
Alex
Jaime Valencia
Can you elaborate on exactly what you're looking for??
If you mean backup all in 1 click that's not supported, you need to backup CUBE and CUCM separately
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
thanks for the reply.
we have upcoming project with CUCM 7.0, but we are really tight in timeframe. I have CUBE in the lab. I want to configure everything such as dialplan, users, BAT, .... in CUBE, then when we receive CUCM, restore the configuration to CUCM. in this case, we can catch up with project.
thanks for the suggestion.
Alex
NO, BAT and CUBE just cannot be in the same sentence as they don't even belong to the same technology.
You save your sh run in CUBE and use DRS in CUCM.
You can do all the CUBE config, but that's it. CUBE CONFIG.
CUCM config STAYS in CUCM.
java
java
