CUCM configuration
Wanted to ask a simple question.
When the a cluster has for example 2 subs and a pub, to configure a user one can login to any server and perform the change since database is common? Or whats the common practice?
Re: CUCM configuration
If you mean configure a user to access CUCM admin it doesn't matter where you create it, it can access any server in the cluster
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks.
Same thing should be true for configuring phone too ? For user on sub-2 being configured from sub-1.
Yes, same thing for phones.
That's the whole concept of having a cluster, whatever you configure in 1 server replicates to the others
java
java
124
