CUCM Database Migration
Hi all,
I need to upgrade a CUCM from 5.1.2a to 7.1.5SU4 on 7845-I1 servers, on my lab i have a spare box to test the upgrade path. I'm using the folowing procedure in the lab, but for same reason i get always a failure:
1- I have take a backup from the production server cluster
2- I have instaled release 5.1.2a on my lab server (without node and device licences  )
3- I have made a restore wit success  (in the licence unit report i get -2 node licences and - 1000 devices units)
4- I uprade to 5.1.3b without success, at the end of the upgrade i get the following error :
11/09/2011 19:54:06 CCMInstall|(CAPTURE) installFull  rc[1]|<LVL::Debug>
11/09/2011 19:54:06 CCMInstall|(CAPTURE) installdb Failure [-i] 1|<LVL::Debug>
11/09/2011 19:54:06 CCMInstall|(CAPTURE) Stop DBMS|<LVL::Debug>
11/09/2011 19:54:06 CCMInstall|(CAPTURE) su -c 'if [ -f /usr/local/cm/db/informix/local/ids.env ]; then source /usr/local/cm/db/informix/local/ids.env l2; fi ; onmode -yck' - informix|<LVL::Debug>
11/09/2011 19:54:06 CCMInstall|(CAPTURE) cm-dbl-install [1]|<LVL::Debug>
11/09/2011 19:54:06 CCMInstall|Internal Error, File:instMain.c:1403, Function: handlePhase(), Failed to exec command: "/partB/usr/local/bin/base_scripts/env.sh nice -n 19 /usr/sbin/chroot /partB /usr/local/cm/script/6.1.3.3000-1/cm-dbl-install L2 PostInstall 6.1.3.3000-1 5.1.2.3119-1 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<LVL::Critical>
11/09/2011 19:54:06 appmanager.sh|CCMInstall --upgrade ERROR|<LVL::Error>
11/09/2011 19:54:06 upgrade_manager.sh|Applications upgrade failed|<LVL::Error>11/09/2011 19:54:06 upgrade_install.sh|Cleaning up download...|<LVL::Info>
11/09/2011 19:54:06 upgrade_install.sh|Removing /common/download/cisco-ipt-k9-patch6.1.3.3000-1.*|<LVL::Info>
11/09/2011 19:54:08 upgrade_install.sh|Removing /common/download/6.1.3.3000-1|<LVL::Info>
11/09/2011 19:54:11 upgrade_install.sh|Cleaning up misc...|<LVL::Info>
11/09/2011 19:54:26 upgrade_install.sh|Dumping /usr disk usage to /usr/local/platform/conf/usr_du_out.txt|<LVL::Info>
11/09/2011 19:54:27 upgrade_install.sh|Cleaning up rpm_archive...|<LVL::Info>
11/09/2011 19:54:27 upgrade_install.sh|Removing /common/rpm-archive/6.1.3.3000-1|<LVL::Info>
11/09/2011 19:54:37 upgrade_install.sh|CSA Status = 0|<LVL::Debug>
11/09/2011 19:54:37 upgrade_install.sh|/etc/init.d/ciscosec start|<LVL::Info>
11/09/2011 19:54:39 upgrade_install.sh|(CAPTURE) Starting ciscosec:  [  OK  ]|<LVL::Debug>
11/09/2011 19:54:39 upgrade_install.sh|Stop IOWAIT monitor|<LVL::Info>
11/09/2011 19:54:39 upgrade_install.sh|1|<LVL::Debug>
Since i dont have the licences for the lab server is this a valid procedure to test the database upgrade ?
1 REPLY
That doesn't seem to be a valid upgrade, 5.1(3) is the minimum you need.
Table 10     Export Restricted Supported Cisco Unified  Communications Manager Upgrades for Release 7.1(5b) through 7.1(5x)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp287966
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
439
