CUCM db replication problem
Hello, after reseting DB Layer Monitor Service, db replication is out of order in the cluster. RTMT is showing a replication status of 3 for publisher and 0 for subcriber node.
I try to stop replication on sub:
utils dbreplication stop SUB
=>replication stop correctly
I try to stop replication on pub:
utils dbreplication stop PUB
=> replication stop correctly
admin:utils dbreplication stop
This command will delete the marker file(s) so that automatic replication setup is stopped
It will also stop any replication setup currently executing
Deleted the marker file, auto replication setup is stopped
Service Manager is running
A Cisco DB Replicator[STOPPING]
Commanded Out of Service
A Cisco DB Replicator[NOTRUNNING]
A Cisco DB Replicator[STARTED]
Completed replication process cleanup
Then try to reset replication:
utils dbreplication reset all
=> Failure with the following error
command failed -- Enterprise Replication not active (62)
Best regards.
Julien.
  • IP Telephony
Hall of Fame Super Red
Re: CUCM db replication problem
Hi Julien,
You may be hitting this bug, it sure does sound like it.
CSCso82088 Bug Details
"utils dbreplication reset all" displays misleading failure message
Symptom:
Once database replication is stopped on all the nodes and then if the 'utils
dbreplication reset all' command is executed on the Publisher - it fails with
following error:
admin:utils dbreplication reset all
Replication reset is in progress. Replication setup will continue in background.
Please watch RTMT replication state on all nodes. It should go from 0 to 2.
When all subs have an RTMT Replicate State of 2, replication setup is complete.
If RTMT Replicate State shows 4, there is an error in replication setup.
DbMon correctly signalled
admin:
Workaround:
None
The replication eventually establishes successfully. Use the following command
to verify the replication status on all nodes in the cluster:
"show perf query class "Number of Replicates Created and State of Replication"
If the Replicate_State counter in the output of above command is 2, then it
means that replication is good.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.1(1.9901.136)
Fixed-In
6.1(2.9901.43)
6.1(2.1109.1)
7.0(0.66666.1)
7.0(0.66666.2)
6.1(3.1000.16)
Hope this helps!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Thanks Rob for this bug id, but it seems replication status is stuck on 3 for pub and 0 for sub... May be i have to wait after doing this procedure.
admin:show perf query class "Number of Replicates Created and State of Replication"
==>query class :
- Perf class (Number of Replicates Created and State of Replication) has instances and values:
ReplicateCount -> Number of Replicates Created = 393
ReplicateCount -> Replicate_State = 3
==>query class :
ReplicateCount -> Replicate_State = 0
Thanks again.
Julien.
Hi Julien,
You are most welcome my friend! Give it some time to repair :) Don't forget the word "eventually" in the Bug notes.
Cheers!
Rob
Hi Rob, unfortunatly, replication is always bad. I have tried repair, reset all, cluster reset... nothing is hapenning. I will program a cluster reboot during the night.
Julien.
Hello, just to inform that after rebooting both CUCM, replication is now OK.
Julien.
I am having same concern for the database repliction for subscriber2.
DB is getting replicated between Pub , Sub 1. With Sub 2, there is noreplication happening. I checked in RTMT tool also, for PUB & SUB1, the Replicated Created it shows. But for Replicated count in Sub2 it shows none.
Where in status count for Pub & Sub1 is " 3" & Sub 2 is none.   I believe it should show sattus count = "2" .
So cannot understand why count = "3"
But after using " dbreplication reset all " command, after some time when i check with " utils dbreplication status"  in Pub, it shows the error logs of replicated between Pub & Sub1. But Sub2 is still not listed in the node option within "utils dbreplication status".
What could be the reason. ?
CUCM's are in single cluster
Pub IP = 10.5.x.x /24
Sub 1 IP = 10.5.x.x
Sub 2 IP = 10.6.x.x
CUCM is different VLAN
Please suggest
Thanks & Regards,
Navin
Can anyone advise on which release of 6.1 this is fixed in?
Bug tool advises:
Fixed in: 6.1(2.9901.43) & 6.1(2.1109.1)
Assuming these are engineering specials?
Mention in 6.1(2) release notes as open caveat.
No release notes for 6.1(2)SU1 6.1(2)SU1A
Fixed in: 6.1(3.1000.16)    6.1(3)
No mention of bug fix in 6.1(3), 6.1(3a) or 6.1(3b) release notes
6.1(3.9999.1)    Assuming this is an engineering special?
No mention of bug fix in release notes for 6.1(4), 6.1(4a), 6.1(5)
Many thanks, Michael
4608
