CUCM end user
Dear all,
CCM in integrated with AD, but when i am trying find user in user management>>end user.... unable to find.
please help me how to find end user and associate device to that user.
Out put would be great!!
AteeQ
Re: CUCM end user
Should be appearing there
Perform a manual LDAP sync or check the LDAP sync schedule to see how often it is updated
Your LDAP credentials may be failing -- so no SYNC
Re: CUCM end user
Thanks for your reply.
As per org. policy i cant go manually we have find where is the problem.
is there any other way to solve this problem.
AteeQ
Re: CUCM end user
Make sure the SN field is not empty for the user, if still no avail, look at sync traces.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
203
