CUCM equivalent to CME silent button commandHi
Hi, I have a customer moving from CME to CUCM 8.5.
In the CME config they use the button1s1 command which enables the silent ring feature for the line. Lines on other buttons will still ring.
Is there any way to mimic this on CUCM?
CUCM DND turns off the ringer for all lines on the device.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CUCM equivalent to CME silent button commandHi
Hi James,
Well you can the Ring Setting - Phone Idle & Phone Active to Flash Only
on Line 1 under the DN config page itself. This would have no effect on the other
lines on the phone
Cheers!
Rob
Hi James,
lines on the phone
Cheers!
Rob
Rob you are a superstar
Hey James,
Thanks for your kind words buddy, but I've put up so many terrible answers here
that I should have probably been banned from CSC at this point Hahahaha!
Here's one from yesterday...yikes!! What was I thinking??
https://supportforums.cisco.com/thread/2117495?tstart=30
Glad to be of some small help here.
Cheers!
Rob
360
