CUCM - Error message when apply Patch
Hi Guys,
To solve the problem about bug I am trying to do update of CUCM 8.6(2)SU2 to CUCM 8.6(2)SU3. This file is bigger, and when I try to do upload appear the error message. I check the MD5 and it is Ok. I suspect that problem is any firewall in the network Customer, but, the Customer told me that there is not firewall. Following the message error:
admin:utils system upgrade initiate
Warning: Do not close this window without first canceling the upgrade.
Source:
1) Remote Filesystem via SFTP
2) Remote Filesystem via FTP
3) Local DVD/CD
q) quit
Please select an option (1 - 3 or "q" ): 1
Directory: \
Server: 172.16.64.26
User Name: teste
Password: *****
Please enter SMTP Host Server (optional):
Checking for valid upgrades.  Please wait...
Available options and upgrades in "172.16.64.26:\":
1) UCSInstall_UCOS_8.6.2.23900-10.sgn.iso
2) ciscocm.dst-updater.2012j-1.el5.8.6.2.cop.sgn
q) quit
Please select an option (1 - 2 or "q" ): 1
Accessing the file.  Please wait...
Downloaded 193 MB.
The remote file could not be accessed or fully downloaded. Please verify the fil        e permissions or check the remote server's status.
admin:
Any have idea, about this?
Wilson
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Simply copy the ISO to datastore on the server and then mount it as DVD in vSphere and ensure it is set to connected, then you can use the CLI to do the upgrade as local upgrade.
HTH,
Chris
I'd set a SFTP in the same network as the server and try again if you suspect of connectivity problems.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Javalenc,
The Customer don´t agree, but, I suspect that the any firewall are blocked, because, the file start and more or less 100Mb he stopped.
Wilson
If you are unable to try a different SFTP, then if this is an MCS server burn the ISO to DVD and try it that way, or if UCS/virtulized deployment copy the ISO to datastore on UCS and boot locally.
HTH,
Chris
Hi Chris,
I will try to do your recommendation and inform after. In my case are using the virtualized environment.
Wilson
Hi Wilsonsant,
you can use the local DVD on your server, or you can use your client DVD
Anas
please rate all helpful posts
HTH,
Chris
Hi Anas,
In my case I am using the virtual machine.
Wilson
VIP Purple
Hi Wilson,
In addition to great tips , please try entering  / in directory path and check.
regds,
aman
Re: CUCM - Error message when apply Patch
Hi All,
I am eliminating the possibility. Was verified the md5 it is Ok. Configured two TFTP Server and I believe that it is Ok. Now I will try to do the suggest by Chris.
Wilson
520
