Community Member
CUCM event/system/application Logs
Our phones are rebooted just now. When I login to the CUCM, all of the phones are already registered normally.
How can i get the logs on what has been happening, like event, system, or application logs.
Thank you
Re: CUCM event/system/application Logs
since there is no version i will assume a linux appliance, use RTMT to pull the logs.
if windows simply open the event viewer
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
I am sorry, I forgot to put the version.
It is CUCM 6.1.
Thank you,
587
