CUCM - extension mobility question
we are using EM, for users that goes to different places, the model we are using is a centralized, with different CCS and partitions for each office, for having local calls using its respective Local GW. The question is, when the user loggins in, the user should get the local CCS for make local calls without care where the user is, how could i do that?
example:
the user could loggin in anywhere using EM, and the behavior expected is:
main office : the user must have the main CCS for having Local calls using the Main office´s GW
office A: the user must have the office A CCS for having local calls using the office A´s GW
office B: the user must have the office B CCS for having local calls using the office B´s Gw
how coud i do that?
thanks
Re: CUCM - extension mobility question
Use device mobility
Device Mobility
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Or use block partitions, css and route patterns.
so the css on the device is used for the call path and the line css is used for rights.
there are some good cisco docs available for this.
161
