11-05-2013 11:12 PM - edited 03-16-2019 08:15 PM
I have a CUCM 8.6 with MGCP gateway, is there a way for a live monitor of the FXO lines either from the operator phone or any solution to know if they are busy and who is using them?
Best regards.
Solved! Go to Solution.
11-11-2013 09:36 AM
Hi Marc,
You can run the debugs like debug mgcp packets/events to get the live status of the FXO lines and configure them to throw the output on a TFTP server. There is no software built to live monitor these lines.
Again if you want to know who is using these lines, probably you need to install a CCTV near the analog phone
Akhilesh Singh
11-11-2013 09:36 AM
Hi Marc,
Akhilesh Singh
11-11-2013 10:24 AM
Hehe
Ok thx :)
11-11-2013 11:22 AM
You could use also RTMT with the Cisco MGCP Gateways>FXOPortsActive monitor, but it will only show that a port is in use, not who's using it.
Gareth
