09-29-2014 08:56 AM - edited 03-17-2019 12:19 AM
We are currently using phone-preffered call recording, but we have some phones we need to record over SPAN. We would like to use gateway-preferred recording. I have setup SIP trunk to recording enabled gateway 2911 and did external call to phone should be recorded, but nothing happened.
Can you please help me and point me to correct documentation?
I'm refering this http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/recordng.html#pgfId-1119797
and this
problem is that there is something about "UC Gateway Services API" and that CUCM registers to gateway over this API but I couldn't find proper documentation which tells me how to configure it correctly.
I need just
1. make inbound call through gateway to phone (7960) with gateway preffered recording enabled
2. get SIP INVITE to my recorder and RTP streams from gateway together with JTAPI signalization from CUCM to my recorder
09-29-2014 09:26 AM
What recording product are you using and are you sure that it supports voice gateway media forking?
Most products can support phone or SPAN based recording but the only product that I am aware of that can support gateway media forking is Cisco's own MediaSense product.
http://www.cisco.com/c/en/us/products/customer-collaboration/mediasense/index.html
09-30-2014 12:20 AM
Recording product is not important currently.
We do not want to fork streams on gateway with dial-peer and media class which points to recorder profile.
We need to set on phone DN gateway preferred recording and get RTP stream from gateway instead of phone. And I cannot find any related documentation about this. only common description, but not sample configuration which tell me what I need and how enable on gateway to enable this type of recording.
09-30-2014 02:24 AM
I was lookig for this configuration which is hard to find. So feel free to use it.
ip http server
ip http authentication local
no ip http secure-server
ip http max-connections 100
ip http timeout-policy idle 600 life 86400 requests 86400
http client connection idle timeout 600
uc wsapi
message-exchange max-failures 2
source-address 192.168.2.11
probing interval negative 10
probing interval keepalive 255
probing max-failures 5
provider xmf
remote-url 1 http://192.168.111.111:8090/ucm_xmf
where remote-url 1 is CUCM xmf application
07-01-2015 01:59 PM
Does this configuration work for you? If so, can you specify what exactly the source-address refers to as well as the remote-url?
10-16-2014 05:58 AM
