Community Member
cucm > freepbx route pattern
So I have setup cucm with a sip trunk to freepbx, There are some feature codes built into freepbx that I would like to use and im not forsure how to setup the route pattern.
Right now I have the following route patterns configured in cucm:
.859[2-9]XXXXXX
I am looking for a way to route *47 or *49 or any number prefixed with an *.....im ok if I need to do 9*47
any ideas?
Hall of Fame Super Silver
Re: cucm > freepbx route pattern
* is acceptable digit in CUCM RP, so what is the issue?
Community Member
I dial *4 and before I get to the 7 I get an automated message stating "your call cannot be completed as dialed"
Do you have a matching route pattern for it?
The ones you listed would not do it.
Community Member
I don't that was my questions, What route pattern would I use.
Whatever pattern you are trying to match, what are you dialing exactly?
Chris
213
