CUCM H.323 Gateway / Outbound calls working but no voice
i`m playing with my lab and have a problem with cucm h.323 voice gateway perform an outbound call throug my sip provider.
I can perform an outgoing call, the other side is ringing but i hear nothing. And before the call is established i hear no dial tone on my cisco phone. I thing this is a maybe codec problem?
Here are the voice gateway config:
voice class codec 1
codec preference 1 g711alaw
voice class h323 1
  h225 timeout tcp establish 3
  call start slow
  no telephony-service ccm-compatible
  ccm-compatible
dial-peer voice 130 voip
description *** from CUCM to GW ***
translation-profile outgoing SIP-Outgoing
answer-address 1...
voice-class codec 1
dtmf-relay h245-signal
no vad
dial-peer voice 140 voip
description *** from GW to SIP Provider ***
destination-pattern 0T
session protocol sipv2
session target dns:sip.sipgate.de
session transport udp
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
In the CUCM regions i have configured G.711 .
What do i wrong?
Jason
add following lines to gateway router global config, to see if it helps..
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
Pls rate the post if it helps.
GP.
Sadly, no sucess. Here is my global voice config:
voice service voip
no ip address trusted authenticate
redirect ip2ip
fax protocol pass-through g711alaw
h323
modem passthrough nse codec g711alaw
sip
  bind control source-interface FastEthernet0/0
  registrar server expires max 3600 min 3600
  redirect contact order best-match
  localhost dns:sip.sipgate.de
Hi Jason.
Try to use g711ulaw as codec.
Is  your VG behind NAT  or Firewall?
Where your IP Phones are registered to?
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Re: CUCM H.323 Gateway / Outbound calls working but no voice
Hi Carlo,
i`ve already tried this codec. Th VG is behind a Firewall.
But before i started this LAB the VG was configured as CME and with this configuration calls worked fine. :-/
I have already tried to erase config on VG with no CME configuration.
Any further suggestions? :-)
Thanks and happy new year.
Hi Jason.
Which IOS version and CUCM version are you using?
Can you please post the entire VG config.
Carlo
Im using this IOS -> c2800nm-adventerprisek9-mz.151-4.M2.bin
See attached config.
Hi Jason.
You config is ok.
Please send me the output of a show rtp connections and a show call active voice compact during an active call.
Carlo
Hi Carlo,
here are the outputs:
  A/O FAX T Codec       type        Peer Address       IP R:
Total call-legs: 2
        24 ANS     T13    g711alaw    VOIP        P1002     192.168.5.10:24580
        25 ORG     T13    g711alaw    VOIP        P0049301234567     62.53.235.118:41064
and show rtp connections is no command on the router only rtp call and rtp statistics, but both show "no active call found"
show rtp call
No Active calls found
show rtp statistics
I don`t know, but should "P1002" show public extenstion instead of internal "1002" number?
Here is also a debug of ccsip calls if the call is established and i think it looks ok or what do you think?
*Jan  3 18:37:55.167: //32/806C039B0E00/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4BEFE638
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 0049301276543
Called Number            : 0049301234567
Source IP Address (Sig  ): 192.168.5.99
Destn SIP Req Addr:Port  : 62.53.230.92:5060
Destn SIP Resp Addr:Port : 62.53.230.92:5060
Destination Name         : sip.sipgate.de
HQ#
*Jan  3 18:37:55.167: //32/806C039B0E00/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 99 (tx), 99 (rx)
Source IP Address (Media): 192.168.5.99
Source IP Port    (Media): 16484
Destn  IP Address (Media): 62.53.235.118
Destn  IP Port    (Media): 55342
Orig Destn IP Address:Port (Media): [ - ]:0
Any idea Carlo?
Hi Jason.
I assume that you are behind nat.
If so try to add these commands:
sip-ua
nat symmetric role  passive
nat check-media-src.
Hope this helps.
Carlo
Ok. Now i tried to change the sip provider with another sip provider. And with this provider the call can be established and both sides hear each other but before the call is established ,i hear sadly still no ringtone. :-(
If i use a third party softphone it worked so it have to be in context with VoiceGW/Call Manager configuration?
UPDATE:
Ok, if i use g711ulaw it works with the ringtone but i don`t know why? I thougt g711ulaw is for America/China only?
UPDATE:
Wuahh im confused. if i use ulaw the ringtone worked but the voice did not work anymore
Hi Jason.
In many cases, SIP providers use G711ulaw as preferred codec but G711alaw should also work.
No particular config is required between CUCM and H323 gateway.
The only thing I would pay attention is on NAT.
Please tell me if applying nat commands in my previous post.
HTH.
Carlo
1775
