Highlighted
CUCM H225 stack process error similar to CSCtc48579
Hi Community Members,
We're facing an issue with incoming ISDN PRI calls from the PSTN. It only happens when calling from specific numbers.
isdn switch-type primary-dms100
In the CUCM trace I see the following error:
17:33:51.114 |ProcessH225Message::decodeUuie ** ERROR  rc=4
D0081S: End of input reached before message was fully decoded; check PDU #5 'H323-UserInformation'.
This looks like CSCtc48579, but this is the platform:
c2900-universalk9-mz.SPA.151-4.M2
Active Master Version: 8.6.1.20000-1
Already tested with the command "signaling forward unconditional" but no luck. Attached the complete UUIE error.
Thanks in advance.
Carlo
I just opened a TAC case for this.
Carlo
By the way, the problem was in the Voice GW I was using H.323 SS, changed back to FS (default) and that fixed the issue.
440
