CUCM hardware compatibility matrix
Hi All,
Currently I am using CUCM 8.0 on MCS7845H2-K9-CMA2.  As CUCM 8.0 is going out of support from 31st October 2014, I am planning to upgrade it to CUCM 8.6 and then CUCM 9.0.
Could you please advice if i can use my existing hardware to perform above upgrade and can i run CUCM normally with all features / move, add, change.  In one of the documents i read that above hardware can be used for "bridge upgrade".
What exactly is "bridge upgrade" and can it support normal operations of CUCM.
Thanks in advance.
1 REPLY
VIP Purple
Hi, the compatibility matrix
the compatibility matrix says MCS7845H2-K9-CMA2 model is supported only for bridged upgrades.What at the best u can do is upgrade to 8.6 or 9 , take backup and restore backup on new compatible hardware.
Bridge is supported in Non-production only.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
regds,
aman
94
