cucm ibm server 7925I4
Hi, Seems as though I'm having a ghard drive failure
on one of my servers. Trouble is that I'm not sure I'm can identify the correct drive
- 2 in system. Can you point to drive in bay 0 or 1 please?
Oct 22 04:17:58, , Warning,  kernel, : mptbase: ioc0: attempting target reset! (sc=cdc8e200), 13049
Oct 22 04:17:58, , Warning,  kernel, : scsi0 : destination target 1, lun 0, 13050
Oct 22 04:17:58, , Warning,  kernel, :         command = Write (10) 00 13 83 e2 cf 00 00 08 00 , 13051
Oct 22 04:17:58, , Warning,  kernel, : mptbase: ioc0: target reset: SUCCESS (sc=cdc8e200), 13052
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0: RAID STATUS CHANGE for PhysDisk 1, 13053
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0:   PhysDisk is now failed, 13054
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0: RAID STATUS CHANGE for PhysDisk 1, 13055
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0:   PhysDisk is now failed, out of sync, 13056
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0: RAID STATUS CHANGE for VolumeID 1, 13057
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0:   volume membership of PhysDisk 255 has changed, 13058
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0: RAID STATUS CHANGE for VolumeID 1, 13059
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0:   volume membership of PhysDisk 255 has changed, 13060
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0: RAID STATUS CHANGE for VolumeID 1, 13061
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0:   volume is now degraded, enabled, 13062
Oct 22 04:18:11, , Info,  kernel, : mptbase: ioc0: RAID STATUS CHANGE for PhysDisk 1, 13063
Re: cucm ibm server 7925I4
I am not sure from the output you have pasted. I have seen syslog messages like the following
Problem due to Hard Drive on ATA1 :
Jul 11 00:00:42 PPHUCMPub kern 3 kernel: ata1: translated ATA stat/err
0x51/40 to SCSI SK/ASC/ASCQ 0x3/11/04
Jul 11 00:00:42 PPHUCMPub kern 4 kernel: ata1: status=0x51 { DriveReady
SeekComplete Error }
Jul 11 00:00:42 PPHUCMPub kern 4 kernel: ata1: error=0x40 {
UncorrectableError }
If you run a 'show hardware', does it show any relevant information about the hard drives and their states ?
- Sriram
Also, keep the following defect in mind : http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti52867.
If the model is set to WD2502ABYS AND the firmware version is set to 3B04, the server is impacted by the
defect.
Firmware download link : http://tools.cisco.com/squish/8531ee
Readme :
http://www.cisco.com/web/software/283046743/32751/7816-i4_782x-I4_Firmware_Updatev10-Readme.pdf
- Sriram
Well the server itself had "hung" but after a re-boot - no errors were found from a "show hardware" command
523
