09-26-2017 12:22 PM - edited 03-17-2019 11:14 AM
I have the following scenario, and i need to calculate the ICCS traffic and additional traffics like database.
All the solutions will be at version 11.5 or 11.6 (UCCX)
Datacenter:
2 x CUCM (1 Pub 1 Sub)
1 X UCCX HA
2 X Cisco IMP
First Remote Site with Local Redundancy:
1 x CUCM Sub
1 X UCCX HA
1 X Cisco IMP Sub
Second Remote Site with Local Redundancy:
1 x CUCM Sub
1 X UCCX Stand Alone
1 X Cisco IMP Sub
CUCM split cluster bandwidth requirements:
ICCS real-time bandwidth - 1.5 Mbps
Database/firewall synchronization bandwidth - 1.5 Mpbs for each remote SUB in your case just one so 1.5 it is
Total CUCM requirements = 6 Mbps
My doubt is how to calculate the Total bandwidth required between the sites = (Total ICCS bandwidth + Total database bandwidth)
UCCX:
based on 10K BHCA (How can i calculate this?)
UCCX to UCCX server synchronization - 1.2 Mbps
UCCX to UC Manager JTAPI - 0.8 Mbps
Total = 2 Mbps
Source - CCX SRND
IMP
All IM and Presence nodes must have a minimum bandwidth of 5 Mbps, and an additional 5 Mbps for the cluster for database synchronization.
Total of = 10 Mbps for each remote subscriber IMP
Source - IMP SRND
Am i correct with my results?
Leonardo Santana
Solved! Go to Solution.
09-27-2017 11:59 AM
Hi Leonardo,
Based on the design/admin guides for CUCM, UCCX and IM&P your assumptions look correct as these numbers are defined exactly as you stated.
You can refer the following couple of posts that had similar query
https://supportforums.cisco.com/t5/ip-telephony/bandwidth-capacity-question-cucm-uccx/td-p/1958017
Also, the information on pages 103-108 of the following doc is useful in calculating how to allocate bandwidth between sites in a UC deployment with Voice/Video
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/cac.pdf
Manish
- Do rate useful posts -
09-27-2017 11:59 AM
Hi Leonardo,
Manish
